11 years, 8 months ago.
Reading the temperature sensor and the internal voltage reference
Is it possible to use AnalogIn() or some other high level API to read the temperature sensor, or do I need to access the registers directly? AnalogIn() takes a pin name as a value, but there are no pins for the temp sensor and VREFINT.
Affordable and flexible platform to ease prototyping using a STM32F030R8T6 microcontroller.
Which temp sensor do you plan to use ? I use LM35 and LM60 using analogIn(AnalogPin) and it works. I used Nucleo and FRDM. Both gave me the correct temp reading.
HTH
posted by samira samilan 01 Apr 2014
I plan to use the STM32F030R8T6's internal temp sensor. It is connected to ADC Channel 16.
posted by Pekka Ahmavuo 02 Apr 2014
I decided to publish an example of how to do this. I am working on a mod that will simplify the declarations within mbed and make it more user friendly. My code is here: https://developer.mbed.org/users/sixBase3/code/Nucleo_read_analog_value_intADCch/
posted by Bill Bellis 31 Mar 2016
The ST processors have a internal temp sensor connected to the ADC. You can use the cmsis interface. Much easier than direct register access. Load the mbed-src lib and look into stm32f0xx_adc.c There you can find ADC_TempSensorCmd(ENABLE); ...
Thanks! The internal temp sensor was what meant, although I didn't clearly express that in my question.
