11 years, 12 months ago.
working in mbed with external power supply>
i wanted to power up mbed with external power supply(battery). i could power up the mbed, but the problem is my program which i dumped into the mbed is not running? what may be the problem??
11 years, 5 months ago.
To work with external power supply, Is there any necessity to connet VB (pin3) a 3.3 volt something like that ? I mean, should i connect pin3 to 3.3 Volt? (I won't use RTC)
11 years, 11 months ago.
You must connect power to P2 (second pin). Then your program should run as expected.
How are you powering it? Which voltage, which pin?
posted by Erik - 27 Mar 2014
