12 years ago.
Problem with loading image from SD card using SPI_TFT_ILI9341 library with FRDM-KL25Z
Hi, I'm wondering if anyone has successfully used SPI_TFT_ILI9341 library created by Peter Drescher to load a 16-bit BMP image and display it on 2.2" TFT LCD. I tried different images converting using GIMP and all of them produced the same result: white background with black lines as shown below.
/media/uploads/kenno/img_20140317_224436.jpg
The source code can be found here: https://mbed.org/users/kenno/code/frdm_tft_ili9341/
If anyone can shed some light, I'm very appreciated. Thank you.
Ken
I am having the exact same issue, but with a different lib (Peter Drescher's lib is what I am using)...same thing...just garbage on the screen.
posted by Jerod Weaver 18 Mar 2014
9 years, 11 months ago.
hi did you get the answer? i am getting same problem pleas help me thanks
