12 years ago.
How to use gets function?
Hello all,
I have question about gets function: Here is my part of code:
int main() { pc.baud(115200); pc.printf("Test Print \n\r "); char instr[128]; char c; while(1) {
if (pc.readable() >0) { pc.gets(instr, 5);
if(( instr[0] == 'L') && ( instr[1] == 'A')) {
long num = atoi(&instr[2]); pc.printf("I got '%i'\n\r", num);
while (pc.readable()) { c = pc.getc(); } } } }
When I wrote pc.gets(instr, 5); and try to send command via Hyper Terminal:
Sent receive LA123 = > 12 my micro controller respond quickly and cut last number. LA12 => 12 it’s add 0 in the end of my string and micro controller respond quickly LA1 => I need to send twice the commands and get 1.
How I can send string with different lengths and read ones all my numbers without missing anything? I need to send to the motor different length for moving.
Maybe somebody has alternative solution? Where I can read about that function ?
Thank you for your help.
Alex
I don't know where the setting is in hyperterminal, but Teraterm by default only transmits \r for an enter. You need to set it to transmit a \n (also), then gets should terminate once it receives the \n.
posted by Erik - 13 Mar 2014
