12 years, 1 month ago.
Flash Magic
Once I try to start flash magic it says that it cant communicate because the COM port may be being used by other applications? HELP. I have a sainsmart NXP LPC1768 dev board with 3.2 LCD screen.
That probably means you still have Hyperterminal or some other application running that is using the COM port. Close these applications and/or select the correct COM port in the flashmagic window. You can check the available COM ports in your windows device manager.
