12 years, 1 month ago.
Compass HMC5883L gives same reading
I am using a modified library for HMC5883L (http://mbed.org/users/higedura/code/dotHR_EKF_phithe/file/0c42db451cb9/HMC5883L.cpp) which has the adition of:
float HMC5883L::getHeading()
    float x = getMx();
    float y = getMy();
    float z = getMz();
    float heading = 0.00;
    if(y > 0)
        heading = 90 -((atan(x/y))*(180/PI));
    else if(y < 0)
        heading = 270-((atan(x/y))*(180/PI));
    else if(y == 0 && x > 0)
        heading = 0.00;
    else
        heading = 180.00;
    return heading;
The main code:
HMC5883L compass(p28, p27);
    while(1)
        pc.printf("Compass: %f \r\n", compass.getHeading());
        wait(2);
everything is connected up correctly as I have had this working before but for some reason now everytime I get a heading its always the same.
Ive tried to look into it but I cannot find a solution, does anyone know why the values are the same in each reading taken?
If you just get the X, Y and Z values, does that work? (I assume not). At which point you need to figure out what is changed. If it worked before there is a good chance your wiring is faulty.
posted by Erik - 18 Feb 2014
