12 years, 1 month ago.
Tri-state DigitalOut (0,1,Hight impedance) ?
Hello
To configure dynamically a componant (DRV8834 Stepper driver) I need a pin to "output" hight level, low level and hight impedence level (as if it was left opened).
A pin is configured as DigitalOut so the I can configure it at Hight or Low level but not at Z level.
Is there a way to do this ?
You can use DigitalInOut to make tri-state pins: http://mbed.org/handbook/DigitalInOut. You just need to manually switch it between input and output.
