12 years, 1 month ago.
PWM set up
Hi forum. Hope you are all well.
/* an attempt at PWM without using the mbed registers
#define PINSEL4 (*(volatile unsigned char *)(0x4002C010))
#define PCONP (*(volatile unsigned char *)(0x400FC0C4))
#define PCLKSEL0 (*(volatile unsigned char *)(0x400FC1A8))
#define PINSEL0 (*(volatile unsigned char *)(0x4002C000))
#define PINMODE4 (*(volatile unsigned char *)(0x4002C050))
#define PWM1MR0 (*(volatile unsigned char *)(0x40018018))
#define PWM1MCR (*(volatile unsigned char *)(0x40018014))
#define PWM1TCR (*(volatile unsigned char *)(0x40018004))
#define PWM1MR5 (*(volatile unsigned char *)(0x40018044))
#define PWM1PCR (*(volatile unsigned char *)(0x4001804C))
int main(){
while(1){
PCONP |= 1 << 6; // power up PWM , powered up on reset, not requ
PCLKSEL0 |= 1 << 12; // setting up the clock for pwm, clock = microcontroller clock i.e the prescaler value is 1.
PINSEL4 |= 1 << 6; // p2.4 as PWM1 output
PINMODE4 |= 1 << 9; // enable neither pull-up nor pull-down
PWM1MR0 = 16; // PWM freq = PWM clock/16
PWM1MCR |= 1 << 1; // reset timer on Match0
PWM1MR5 = 8; // PWM duty cycle = 0.5
/* 8 is stored into MR5. therefore now one cycle of PWM waveform consists of 16PWM clock cycles
and for 8 of them the PWM output will be high and for remaining 8 cycles it will be low.
therefore the effective signal produced is a waveform of frequency
(PWM clock/6) with a duty cycle of 0.5
PWM1TCR |= (1 << 0) | (1 << 3); // enable timer/counter
select control mode for each channel(except channel ) and enable the PWM output
PWM1PCR |= 1 << 4; //configure channel 4 as double edge , refer to table 451 pg 519
//settiing bits 2-6 to 0 enables single edge
PWM1PCR |= 1 << 12; //enable PWM for channel 4 output
PWM1PCR |= 1 << 13; // eanble PWM for channel 5 output , no need to configure channel 5 default is to 0 single side rise
I'm trying to get PWM working on any pin 2.4 I've managed to get the pin to light up, but i can't get voltage to vary when i change the value in PWM1MR5. Could someone please point me in the right direction to fix this. Many thanks.
I assume the LPC1768?
First of all, why make your own register definitions? LPC_PWM1->PCR is for the PCR register for example. What you miss for sure is the LER register, you need to write correct bits to cause the match registers to update.
