12 years, 2 months ago.
Help port Dynamixel library for the community
Hello all,
I dabble in robotics and often use Dynamixel servos. I've used Arbotix controllers, the Robotic CM9.04, and a Raspberry Pi using the Robotics Dynamixel libraries. Unforunately, there are no libraries explicitly for the mbed platform. There is an AX12 library floating around here, but it is rather limited. Fortunately, Robotis supplies sort of a library template so that you can adapt their C libraries to your own platform.
http://support.robotis.com/en/software/dynamixel_sdk/sourcestructure.htm
It boils down to the one low level function file in the library where you must fill in your platform's method for doing the given functions.
// Dynamixel SDK platform dependent source
#include "dxl_hal.h"
int dxl_hal_open( int devIndex, float baudrate )
// Opening device
// devIndex: Device index
// baudrate: Real baudrate (ex> 115200, 57600, 38400...)
// Return: 0(Failed), 1(Succeed)
void dxl_hal_close()
// Closing device
void dxl_hal_clear(void)
// Clear communication buffer
int dxl_hal_tx( unsigned char *pPacket, int numPacket )
// Transmiting date
// *pPacket: data array pointer
// numPacket: number of data array
// Return: number of data transmitted. -1 is error.
int dxl_hal_rx( unsigned char *pPacket, int numPacket )
// Recieving date
// Return: number of data recieved. -1 is error.
void dxl_hal_set_timeout( int NumRcvByte )
// Start stop watch
// NumRcvByte: number of recieving data(to calculate maximum waiting time)
int dxl_hal_timeout(void)
// Check timeout
// Return: 0 is false, 1 is true(timeout occurred)
As an example, here is the same file for their linux library:
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <termios.h>
#include <linux/serial.h>
#include <sys/ioctl.h>
#include <sys/time.h>
int gSocket_fd = -1;
long glStartTime = 0;
float gfRcvWaitTime = 0.0f;
float gfByteTransTime = 0.0f;
char gDeviceName[20];
int dxl_hal_open(int deviceIndex, float baudrate)
struct termios newtio;
struct serial_struct serinfo;
char dev_name[100] = {0, };
sprintf(dev_name, "/dev/ttyUSB%d", deviceIndex);
strcpy(gDeviceName, dev_name);
memset(&newtio, 0, sizeof(newtio));
dxl_hal_close();
if((gSocket_fd = open(gDeviceName, O_RDWR|O_NOCTTY|O_NONBLOCK)) < 0) {
fprintf(stderr, "device open error: %s\n", dev_name);
goto DXL_HAL_OPEN_ERROR;
newtio.c_cflag = B38400|CS8|CLOCAL|CREAD;
newtio.c_iflag = IGNPAR;
newtio.c_oflag = 0;
newtio.c_lflag = 0;
newtio.c_cc[VTIME] = 0; // time-out 값 (TIME * 0.1초) 0 : disable
newtio.c_cc[VMIN] = 0; // MIN 은 read 가 return 되기 위한 최소 문자 개수
tcflush(gSocket_fd, TCIFLUSH);
tcsetattr(gSocket_fd, TCSANOW, &newtio);
if(gSocket_fd == -1)
return 0;
if(ioctl(gSocket_fd, TIOCGSERIAL, &serinfo) < 0) {
fprintf(stderr, "Cannot get serial info\n");
return 0;
serinfo.flags &= ~ASYNC_SPD_MASK;
serinfo.flags |= ASYNC_SPD_CUST;
serinfo.custom_divisor = serinfo.baud_base / baudrate;
if(ioctl(gSocket_fd, TIOCSSERIAL, &serinfo) < 0) {
fprintf(stderr, "Cannot set serial info\n");
return 0;
dxl_hal_close();
gfByteTransTime = (float)((1000.0f / baudrate) * 12.0f);
dxl_hal_close();
newtio.c_oflag = 0;
newtio.c_lflag = 0;
return 1;
DXL_HAL_OPEN_ERROR:
dxl_hal_close();
return 0;
if(gSocket_fd != -1)
close(gSocket_fd);
gSocket_fd = -1;
int dxl_hal_set_baud( float baudrate )
return 0;
return 0;
return 0;
//dxl_hal_close();
//dxl_hal_open(gDeviceName, baudrate);
return 1;
return write(gSocket_fd, pPacket, numPacket);
memset(pPacket, 0, numPacket);
return read(gSocket_fd, pPacket, numPacket);
static inline long myclock()
struct timeval tv;
gettimeofday (&tv, NULL);
return (tv.tv_sec * 1000 + tv.tv_usec / 1000);
glStartTime = myclock();
gfRcvWaitTime = (float)(gfByteTransTime*(float)NumRcvByte + 5.0f);
long time;
time = myclock() - glStartTime;
if(time > gfRcvWaitTime)
return 1;
else if(time < 0)
return 0;
So far this is what I've filled in. Please tell me how far off base I am (i filled in a bunch of return 1s to satisfy the compiler):
// Opening device
Serial dxl(P0_0, P0_1); // UART3 TX, RX for LPC4088
dxl.baud(1000000);
return 1;
// Closing device
// Clear communication buffer //DAN's function used elsewhere. proper?
char dumpster = 0;
while (dxl.readable()) {
dumpster = dxl.getc();
// Transmiting date
//dxl.getc() or some sort //DAN
return 1;
// Recieving date
//dxl.getc() of some sort. //DAN
return 1;
// Start stop watch
// Check timeout
//Time function? //DAN
If you guys would like to chip in and knock out a function or two i'd much appreciate it. I'll thoroughly test things and bundle it up and submit it to the repository for all to use. Thanks!
Serial dxl should be global otherwise the different functions cant access that object. You need getc() or putc() to send or receive bytes and you may want to add timeouts to avoid blocking.
Serial dxl(P0_0, P0_1); // Global, UART3 TX, RX for LPC4088
// Opening device
// Serial dxl(P0_0, P0_1); // Global, UART3 TX, RX for LPC4088
// dxl.baud(1000000);
dxl.baud(baudrate); /use the parameter here
return 1;
// Closing device
char dumpster = 0;
// A call to dxl.flush() may be better
// Transmiting date
int i;
for (i=0; i<numPacket; i++) {
while (!dxl.writable()); // wait until you can write, may want to add timeout here
dxl.putc(pPacket[i]); //write
return numPacket; // or -1 when there is timeout
// Recieving date
int i;
while (!dxl.readable()); // wait until you can read, may want to add timeout here
pPacket[i] = dxl.getc(); // read
// Start stop watch
// Check timeout
Thanks for your input. I've incorporated iti and added some more with questions:
dxl_hal.cpp:
Timer t;
// Opening device
//it'd be cool to be able to select UARTs by parameter, but too many different device configurations...
dxl.baud(1000000);
//is there a way to check serial initialization health/status for return?
return 1;
// Closing device
//is there a close method for Serial class?
//dxl.flush(); //.flush() method doesn't exist
char dumpster;
t.reset(); // i think they expect a reset on a dxl_hal_clear()
t.stop();
// Transmiting date
int i;
while ( !dxl.writeable() ); // wait until you can write, may want to add timeout here
return numPacket;
// Recieving date
int i;
while ( !dxl.readable() ); // wait until you can read, may want to add timeout here
//this assuming the number of data to be read matches the expected number to be read (numPacket).
//should i read all available data and compare its length to numPacket? Looks like they want me to
//return the actual number of data received. if they don't match, is that -1 error?
return numPacket; //should i return expected or acutal number of data received?
// Start stop watch
t.start(); //start timer
gfRcvWaitTime = (float)(gfByteTransTime*(float)NumRcvByte + 5.0f); // assuming units of (us), copied from linux SDK
// Check timeout
// Return: 0 is false (no timeout), 1 is true(timeout occurred)
if(t.read_us() > gfRcvWaitTime){ //I'm assuming wait gfRcvWaitTime and gfByteTransTime are in units of (us)
return 1; // timeout!
else return 0;
Also for reference, here is the higher level file that calls dxl_hal.cpp, dynamixel.cpp:
#include "dynamixel.h"
#define ID (2)
#define LENGTH (3)
#define INSTRUCTION (4)
#define ERRBIT (4)
#define PARAMETER (5)
#define DEFAULT_BAUDNUMBER (1)
unsigned char gbInstructionPacket[MAXNUM_TXPARAM+10] = {0};
unsigned char gbStatusPacket[MAXNUM_RXPARAM+10] = {0};
unsigned char gbRxPacketLength = 0;
unsigned char gbRxGetLength = 0;
int gbCommStatus = COMM_RXSUCCESS;
int giBusUsing = 0;
int dxl_initialize( int devIndex, int baudnum )
float baudrate;
baudrate = 2000000.0f / (float)(baudnum + 1);
if( dxl_hal_open(devIndex, baudrate) == 0 )
return 0;
giBusUsing = 0;
return 1;
void dxl_terminate()
dxl_hal_close();
void dxl_tx_packet()
unsigned char i;
unsigned char TxNumByte, RealTxNumByte;
unsigned char checksum = 0;
if( giBusUsing == 1 )
return;
giBusUsing = 1;
if( gbInstructionPacket[LENGTH] > (MAXNUM_TXPARAM+2) )
gbCommStatus = COMM_TXERROR;
giBusUsing = 0;
return;
if( gbInstructionPacket[INSTRUCTION] != INST_PING
&& gbInstructionPacket[INSTRUCTION] != INST_READ
&& gbInstructionPacket[INSTRUCTION] != INST_WRITE
&& gbInstructionPacket[INSTRUCTION] != INST_REG_WRITE
&& gbInstructionPacket[INSTRUCTION] != INST_ACTION
&& gbInstructionPacket[INSTRUCTION] != INST_RESET
&& gbInstructionPacket[INSTRUCTION] != INST_SYNC_WRITE )
giBusUsing = 0;
return;
gbInstructionPacket[0] = 0xff;
gbInstructionPacket[1] = 0xff;
for( i=0; i<(gbInstructionPacket[LENGTH]+1); i++ )
checksum += gbInstructionPacket[i+2];
gbInstructionPacket[gbInstructionPacket[LENGTH]+3] = ~checksum;
if( gbCommStatus == COMM_RXTIMEOUT || gbCommStatus == COMM_RXCORRUPT )
dxl_hal_clear();
TxNumByte = gbInstructionPacket[LENGTH] + 4;
RealTxNumByte = dxl_hal_tx( (unsigned char*)gbInstructionPacket, TxNumByte );
if( TxNumByte != RealTxNumByte )
gbCommStatus = COMM_TXFAIL;
giBusUsing = 0;
return;
if( gbInstructionPacket[INSTRUCTION] == INST_READ )
dxl_hal_set_timeout( gbInstructionPacket[PARAMETER+1] + 6 );
else
dxl_hal_set_timeout( 6 );
gbCommStatus = COMM_TXSUCCESS;
void dxl_rx_packet()
unsigned char i, j, nRead;
if( giBusUsing == 0 )
return;
if( gbInstructionPacket[ID] == BROADCAST_ID )
giBusUsing = 0;
return;
if( gbCommStatus == COMM_TXSUCCESS )
gbRxGetLength = 0;
gbRxPacketLength = 6;
nRead = dxl_hal_rx( (unsigned char*)&gbStatusPacket[gbRxGetLength], gbRxPacketLength - gbRxGetLength );
gbRxGetLength += nRead;
if( gbRxGetLength < gbRxPacketLength )
if( dxl_hal_timeout() == 1 )
if(gbRxGetLength == 0)
gbCommStatus = COMM_RXTIMEOUT;
else
gbCommStatus = COMM_RXCORRUPT;
giBusUsing = 0;
return;
// Find packet header
for( i=0; i<(gbRxGetLength-1); i++ )
if( gbStatusPacket[i] == 0xff && gbStatusPacket[i+1] == 0xff )
break;
else if( i == gbRxGetLength-2 && gbStatusPacket[gbRxGetLength-1] == 0xff )
break;
if( i > 0 )
for( j=0; j<(gbRxGetLength-i); j++ )
gbStatusPacket[j] = gbStatusPacket[j + i];
gbRxGetLength -= i;
gbCommStatus = COMM_RXWAITING;
return;
// Check id pairing
if( gbInstructionPacket[ID] != gbStatusPacket[ID])
giBusUsing = 0;
return;
gbRxPacketLength = gbStatusPacket[LENGTH] + 4;
return;
// Check checksum
for( i=0; i<(gbStatusPacket[LENGTH]+1); i++ )
checksum += gbStatusPacket[i+2];
checksum = ~checksum;
if( gbStatusPacket[gbStatusPacket[LENGTH]+3] != checksum )
giBusUsing = 0;
return;
giBusUsing = 0;
void dxl_txrx_packet()
dxl_tx_packet();
if( gbCommStatus != COMM_TXSUCCESS )
return;
do{
dxl_rx_packet();
}while( gbCommStatus == COMM_RXWAITING );
int dxl_get_result()
return gbCommStatus;
void dxl_set_txpacket_id( int id )
gbInstructionPacket[ID] = (unsigned char)id;
void dxl_set_txpacket_instruction( int instruction )
gbInstructionPacket[INSTRUCTION] = (unsigned char)instruction;
void dxl_set_txpacket_parameter( int index, int value )
gbInstructionPacket[PARAMETER+index] = (unsigned char)value;
void dxl_set_txpacket_length( int length )
gbInstructionPacket[LENGTH] = (unsigned char)length;
int dxl_get_rxpacket_error( int errbit )
if( gbStatusPacket[ERRBIT] & (unsigned char)errbit )
return 1;
return 0;
int dxl_get_rxpacket_length()
return (int)gbStatusPacket[LENGTH];
int dxl_get_rxpacket_parameter( int index )
return (int)gbStatusPacket[PARAMETER+index];
int dxl_makeword( int lowbyte, int highbyte )
unsigned short word;
word = highbyte;
word = word << 8;
word = word + lowbyte;
return (int)word;
int dxl_get_lowbyte( int word )
unsigned short temp;
temp = word & 0xff;
return (int)temp;
int dxl_get_highbyte( int word )
temp = word & 0xff00;
temp = temp >> 8;
return (int)temp;
void dxl_ping( int id )
while(giBusUsing);
gbInstructionPacket[INSTRUCTION] = INST_PING;
gbInstructionPacket[LENGTH] = 2;
dxl_txrx_packet();
int dxl_read_byte( int id, int address )
while(giBusUsing);
gbInstructionPacket[INSTRUCTION] = INST_READ;
gbInstructionPacket[PARAMETER] = (unsigned char)address;
gbInstructionPacket[PARAMETER+1] = 1;
gbInstructionPacket[LENGTH] = 4;
dxl_txrx_packet();
return (int)gbStatusPacket[PARAMETER];
void dxl_write_byte( int id, int address, int value )
while(giBusUsing);
gbInstructionPacket[INSTRUCTION] = INST_WRITE;
gbInstructionPacket[PARAMETER+1] = (unsigned char)value;
dxl_txrx_packet();
int dxl_read_word( int id, int address )
while(giBusUsing);
gbInstructionPacket[PARAMETER+1] = 2;
dxl_txrx_packet();
return dxl_makeword((int)gbStatusPacket[PARAMETER], (int)gbStatusPacket[PARAMETER+1]);
void dxl_write_word( int id, int address, int value )
while(giBusUsing);
gbInstructionPacket[PARAMETER+1] = (unsigned char)dxl_get_lowbyte(value);
gbInstructionPacket[PARAMETER+2] = (unsigned char)dxl_get_highbyte(value);
gbInstructionPacket[LENGTH] = 5;
dxl_txrx_packet();
The example dxl_hal_rx() and dxl_hal_rx() that I showed above will receive or transmit the exact numPacket bytes. The functions will wait and block until this number is reached. You may want to include timeouts in the while loops to break out when the maximum wait time has passed. You could then return the number of bytes that was actually received or transmitted, but it makes more sense to return a -1 indicating error. You dont get any other usable errors back from Serial anyhow,
posted by 08 Feb 2014
