12 years, 1 month ago.
Using RTOS with KL46Z
My project compiles and runs beautifully on mbed LPC1768, likewise on KL25Z, unable to compile for KL46Z target however, compiler reports errors :-
Error: Identifier "OS_TASKCNT" is undefined in "mbed-rtos/rtx/RTX_CM_lib.h", Line: 93, Col: 32
Error: Identifier "OS_CLOCK" is undefined in "mbed-rtos/rtx/RTX_CM_lib.h", Line: 95, Col: 32
Error: Identifier "INITIAL_SP" is undefined in "mbed-rtos/rtx/RTX_CM_lib.h", Line: 241, Col: 37
Error: Identifier "OS_SCHEDULERSTKSIZE" is undefined in "mbed-rtos/rtx/RTX_CM_lib.h", Line: 241, Col: 79
Not essential to run on KL46Z, but would be nice to say "it works on all three."
Thanks
This fork should work with the KL46Z: http://mbed.org/users/marcusbirkin/code/mbed-rtos/
The official one lacks some defines for the KL46Z. I would make them and create a pull request, problem is that I don't know what they should be. That fork has them on the same values as the KL25Z, but since the KL46Z has double the SRAM for example, that might not be ideal.
