13 years, 3 months ago.
TLV320 hang-up in audio.start
immediately after recording some sectors of audio on an SD-card, I want to playback the recorded audio. But audio.start(TRANSMIT) does not return. It hangs in NVIC_EnableIRQ(I2S_IRQn). What happens inside this function?
Running recording and playback seperatly works just fine.
Here is the code:
audio.power(0x02); //power up all TLV320, just not microphone
audio.inputVolume(0.999, 0.999); //Set input volume to max - I don't like to use 1.0 due to rounding errors
audio.frequency(frequency);
audio.format(wordWidth, (2-channels)); //note int mode = 2 - channels
audio.attach(&record); //attach record function to audio interrupt
for(int j = 0; j < 4096; ++j){
circularBuffer[j] = 0; //clear circular buffer
printf("Record\n");
finish.mode(PullUp);
finish.fall(&stopRecording); //attach stop button
recording = true;
audio.start(RECEIVE); //start recording
streamToFile();
printf("Stop: %d\n",write_sector);
audio.stop();
//while(1);
printf("Playback\n");
audio.attach(&play); //attach interrupt handler to send data to TLV320
for(int j = 0; j < 4096; ++j){ //upon interrupt generation
audio.start(TRANSMIT); <<< hang-up
theta = 0;
read4Pointer = 512;
fillBuffer(); //continually fill circular buffer
audio.stop();
printf("Done\n");
while (1);
Meanwhile I got the solution by myself. LPC_I2S->I2SIRQ has to be cleared before the audio.start for playback. Otherwise the settings for recoding will be kept.
