12 years, 1 month ago.
LPC812 RS232
Do I have to do resolder jumpers tu use RS232 connection between PC and LPC812? Or will it work without it? I know it is required to use USB connection, but found no info about RS232.
Thanks in advance!
How are you using it with an RS232 port? If you connect a RS232 converter to your board via the RX and TX arduino pins you don't need to solder anything.
posted by Erik - 31 Jan 2014Yes, this is exactly what I am going to do. Thank You very much Erik
posted by Adrian Ciołek 01 Feb 2014
