12 years, 2 months ago.
11u24 Program Stuck in Memory
I used the following code
Break Your MBED
InterruptIn wakeup(p14);
DigitalOut  led(LED1);
// Pulled from mbed SDK sources but removed mbed_interface_disconnect() call
// since that would cause halt when it tried to disable the interface chip
// which isn't powered up when I am powering the device from VB.
void deepsleep(void)
    // PCON[PD] set to deepsleep
    LPC_PMU->PCON = 0x1;
    // SRC[SLEEPDEEP] set to 1 = deep sleep
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    // Power up everything after powerdown
    LPC_SYSCON->PDAWAKECFG &= 0xFFFFF800;
    // wait for interrupt
    __WFI();
static void dummyHandler(void)
    return;
int main ()
    wakeup.rise(&dummyHandler);  // Setup rising edge interrupt
    led = 1;
    while (1)
        deepsleep();  // Deep sleep until external interrupt
        led = !led;
I added the & to pass by reference to the dummy handler so that I could actually throw a little code in there. Guess what, now when I load new programs to my mbed they will stay on the drive, but the processor will only run this code. I have disconnected usb, pressed power button, etc. Any ideas?
Tim Kyle
poster
I am answering my own question. I did the reset described here. http://mbed.org/cookbook/Unbricking I had to do it when the processor was not asleep.
