12 years, 1 month ago. This question has been closed. Reason: No answers for this question
Windows 7 does not see mbed ?
Need your help ! My computer OS is Windows7 64, after connecting to USB port I can not see mbed under window explorer? Tried to install "mbed Windows serial port driver" but no sucess ! (No problem with windows xp) Need your help
Windows 7 is for text processing, web surfing and gaming. Nothing more. I had problems with huawei e1820 3g stick, win 7 32-bit did not always recognize the stick, i needed to remove the stick and plug it in again.
When using Win 7 ICS, the ICS server corrupted tcp/ip packets. Our win 7 pc is 3.1Ghz dualcore. Our new tp-link 3220 3g router is 400Mhz linux and works perfectly.
11 years, 10 months ago.
I use Win 7 and never see any problem about mbed lpc1768 I think you should try to uninstall the drivers and reboot then reinstall the drivers. Then reboot again. Should work. P.S. When you try to remove the mbed from pc, do "eject mbed" near the clock then remove physically.
