12 years, 2 months ago.
Problem with LocalFileSystem example
I loaded the LocalFileSystem example code as-is and compiled it, and it failed to compile. The error message was: CMSIS Target not recognized. I thought the example code would run as-is without problems, so there must be something I missed. What is happening here and what is the solution. Thank you,
The mbed library is old in the example probably, updating it will remove the issue. However then gives another issue: LocalFileSystem is only available currently on the LPC1768 and LPC11u24: They use a seperate flash IC to implement it, the KL25Z you have does not have LocalFileSystem.
Thank you. I updated the library, so the problem must be that I'm compiling for the KL25Z. I wonder how I would write data to a file on the KL25Z?
