12 years, 1 month ago.
Anyone tried a standalone CMSIS-DAP board?
Interested to know if anyone has used the schematics & firmware on from the HDK to build an mbed CMSIS-DAP board to provide drag & drop programming, serial interface and debug to a board with a bare chip like a LPC1768?
I'm thinking exactly like this attempt, but I gather he should have used a LPC11U37FBD64/501 because it needs 12KB SRAM: http://mbed.org/cookbook/lpc11u35_lpc1768_INTERFACE
Thanks,
Ian
Yeah, you can do that. I have tried to use Arch as a CMSIS DAP board. Arch uses LPC11U24 and has only 8K RAM. It works by reducing memory usage.
by remove dynamically generating MBED.HTM file, reducing some threads' stack size and optimizing code for size. The source code is on https://github.com/xiongyihui/CMSIS-DAP/tree/lpc11u24
posted by 08 Jan 2014
Yep, I've built a hand held display module using parts of the HDK
https://mbed.org/users/ScubaBoy/notebook/prototype-display/
posted by Rob Cawsey 07 Jan 2014Looks great! - do you have any more info on what you did with regards the mbed interface? - which chip did you use?
posted by Ian Chilton 07 Jan 2014I replaced the ISP connector with the mbed interface from the hdk. I'll upload the schematic tomorrow which should help.
posted by Rob Cawsey 07 Jan 2014That would be great - thank you!
posted by Ian Chilton 07 Jan 2014I've uploaded the schematic.
posted by Rob Cawsey 08 Jan 2014Great - thanks!
posted by Ian Chilton 08 Jan 2014
