12 years, 3 months ago.
Answer for using EthernetInterface with RTOS and Serial interrupt
There is a solution for this.
You can fix your code of reading part from current to that.
Current: unsigned char RX_Char = (devicename).getc();
that: unsigned char RX_Char; RX_Char = LPC_UART2->RBR; (LPC_UART2 -> (p28, 27))
If you want to other pin header, you can find the LPC_UART(number) matched pin header you want to use.
Best reagrds.
RawSerial has been introduced to deal with this problem. Just replace Serial with RawSerial and it should work.
