12 years, 3 months ago.
KL25Z board, MMA8451Q configuration?
On the KL25Z board, which is the device configuration ( sampling rate etc.) used on the MMA8451Q library ?
Thanks!
If you check the code you see that it just keeps the chips defaults (many libraries do). So from the datasheet then: The default full scale value range is 2g and the high-pass filter is disabled.The default value is 000 for a data rate of 800 Hz. (From me: That is of course only when you actually also sample it that vast via your connection). It uses also standard 14-bit accuracy.
I am not certain what are you asking, can you specify more? Have you seen the FRDM KL25Z with the accelerometer. It uses default i2c frequency, which is set to 100k.
http://mbed.org/handbook/mbed-FRDM-KL25Z-Examples
posted by Martin Kojtal 27 Nov 20130xc0170
if you check the MMA8451Q datasheet, you see that the device can be configured regarding quite a few parameters. Among others:
The documentation of the library is not telling which is the "full_scale" "output data rates" etc. that is being used. This is just what I want to know.
Thanks for your help, Manuel
posted by Manuel Franquelo 27 Nov 2013
