12 years ago.
What are the eletrical constraints connecting a buzzer to a PWM port?
Dear All,
I'd like to connect a piezo buzzer to a pwm port to create an audible alarm function with the RTC library of Erik Olieman. Alas, I couldn't find any hints about connecting a buzzer to a PWM port, e.g. max. allowed current, necessity of a resistor in series with the buzzer (like e.g. necesary for LEDs), etc.
Any hint and/or link will be very much appreciated.
Thank you very much in advance.
Best regards
Karl
12 years ago.
It depends on which piezo buzzer you are using. Some should be fine directly connected, others will require a driver in between. For example this one: http://www.hobbytronics.co.uk/piezo-transducer-5v can be directly driven from an mbed. Others will require more power.
Also watch out that many piezo buzzers have a built-in oscillator, you turn them on by giving them a power supply, and then they make a fixed tone.
