12 years, 4 months ago. This question has been closed. Reason: probably not possible
Xbee to RJ45
Im new to using mbed and have run into a small problem. I am trying to use web sockets to stream a wave on a graph and as I understand will need to use a RJ45 socket. My current setup is the mbed 1768 connected to a Xbee series 1 which transmits to another Xbee which then connects to a RJ45 socket. I have tried searching on google as to how I can physically connect the Xbee to the RJ45 but I can't seem to find anything close.
Therefore I am wondering if it is even possible and I am missing something obvious, or is it as simple as using the uart pins and two other pins on the Xbee? Currently I ordered a RJ45 socket with breakout board and a usb breakout board for the Xbee and should be expecting them in 2 weeks, so I can not test anything atm. Using windows 7 btw.
Thanks in advanced, Johan
