12 years, 4 months ago.
Mbed MMA7660
can anyone help me program a calibration or configuration code so when i start the Mbed MMa7660 the values are correct?
thanks
How aren't they correct? Sure they have some offset, but accelerometers in general are fairly accurate without calibration, and the MMA7660 also isn't meant to be extremely accurate: its main goal is orientation sensing, if you for example want an AHRS you will need a more accurate device.
But for basic orientation/angle sensing it should be fine without calibration.
