13 years, 5 months ago.
how do I limit the amount of trailing zeros of a float and double?
Creating a json object was relatively simple. The json string is: {"sensorBoardName":["SensorBoard1"],"sensor":{"pH":0.000000}} The "pH": json value should be 0.00 instead of 0.000000. Is there anyway to limit the amount of trailing 0s float produces? Does anyone know if there is a configuration setting in the MbedJSONValue.h library to limit the amount of trailing zeros?
#include "MbedJSONValue.h"
MbedJSONValue SensorData;
float phSensor = 0.00;
char *sbNameKey = "SensorBoardName";
char sbNameValue[BUFSIZ];
std::string s;
* Read a configuration file from a mbed.
if (!cfg.read("/local/settings.cfg")) {
error("Failure to read a configuration file.\n");
* Get a configuration value.
* Then attach the sbNameValue to SensorData json
if (cfg.getValue(sbNameKey, &sbNameValue[0], sizeof(sbNameValue))) {
//printf("'%s'='%s'\n", sbNameKey, sbNameValue);
//Create sensorBoardName value to json object
SensorData["sensorBoardName"][0] = sbNameValue;
SensorData["sensor"]["pH"] = phSensor;
//serialize it into a JSON string
s = SensorData.serialize();
printf("json: %s\r\n", s.c_str());
I edited line 91 in MbedJSONValue.cpp from:
sprintf(buf, "%f", _value.asDouble);
to:
sprintf(buf, "%.2f", _value.asDouble);
The %.2f trimmed the double value to just two decimals places.
Thank you Samuel Mokrani for guiding me in the right direction.
