12 years, 5 months ago.
struct size problem
Hi I have a code:
  1. include "mbed.h"
struct MBAP_TYPE { uint16_t T_ID; uint16_t P_ID; uint16_t LENGTH; uint8_t U_ID; };
int main() { printf("SIZES %d %d %d \r\n",sizeof(uint8_t),sizeof(uint16_t),sizeof(MBAP_TYPE)); }
Anyone could explain me, why "sizeof(MBAP_TYPE)" give me value 8, not 7 ?
Regards Serge
I don't have an mbed currently here to test it, but I guess it is related to the allignment of variables by the compiler. Placing the uint8_t at the beginning of the struct might already make a difference.
Thanks Erik, But this way doesn't work and don't solve my problem, because I would like to use this structure in union with byte array.
Well then you can still do a union, but the order is different, U_ID is then the first byte.
You can also force the compiler to remove the allignment, see: http://mbed.org/forum/bugs-suggestions/topic/4264/. However then at the same time at least non-properly aligned floats apparantly can crash your microcontroller. You don't have floats, but I would rather have overhead of one byte.
posted by Erik - 05 Nov 2013
Thanks Erik, After removing alignment, program works correctly.
posted by Katunin Serge 05 Nov 2013
