11 years, 11 months ago.
internet connectivity
hi guys, I am trying to get internet connectivity on wi-go module with kl25z platform.. I ran the sample program of the wigo.. I got the ip address, I mean ip is assigning to my wi-go module.. it is showing internet connectivity.. but when i am trying to run this ip on browser (it supposed to show wi-go portal) it is not displaying any thing.. i mean web page is not loading at all.. i am connecting through my uni wifi connection ( well i think uni connection has some restrictions).. can u guys suggest what should i do ??
what example are you running on your Wi-Go?
posted by Martin Kojtal 31 Oct 2013
there are some sample programs,provided with wi-go modules like: 1) getting and printing the temp and pressure values. 2) connecting to web server and many more :)
posted by zain aftab 01 Nov 2013
Can you share exactly the link, is it IoT demo posted by Frank? http://mbed.org/users/frankvnk/code/Wi-Go_IOT_Demo/
Provide more details otherwise we can't help you much. I ahve run IoT demo multiple times, no problems at all.
Is there any output on the console which you can share? It might get stuck somewhere so webserver stops.
posted by Martin Kojtal 01 Nov 2013
zain aftab
poster
yeap i am using WI-Go_IOT_Demo
Wi-Go Master V3.3 Firmware build version: Oct 29 2013, 23:57:57
Wi-Go MAC address xx:xx:xx:xx:xx:xx
FTC 1 PP_version 3.4 SERV_PACK 1.11 DRV_VER 7.14.24 FW_VER 7.12.14
Use the slider to start an application. Releasing the slider for more than 3 seconds will start the chosen application. Touching the slider within the 3 seconds timeframe allows you to re-select an application.
The RGB LED indicates the selection: PURPLE - Force SmartConfig. BLUE - Webserver displaying live sensor data. RED - Exosite data client. GREEN - Android sensor fusion app.
if i select purple i get the following result
RunSmartConfig= 1 waiting waiting waiting mDNS Status= a9be Connected
* Wi-Go board DHCP assigned IP Address = 10.253.33.12 mDNS Status= c0be Reset system
after this when i select blue or red (for live web server or exosite avnet site respectively) it doesnt show any thing... means let say if i enter the assigned ip to web browser, nothing happens.. plus i am not able to ping this ip address as well
actually i got the actual problem.. the ip i am getting is assigned by the redirect server. usually when i get this ip on my laptop/iphone, i need to goto redirect page where i enter my university registration details and after it i get the actual internet access (different ip). here on mbed because i can not browse the web page (and can not enter my uni details) i am not able to enter password.. now only solution is either get a separate internet connection (which will be costly) or open the uni web page some how from mbed..
P.S : what do you say now ?? have any other solutions??
