12 years, 3 months ago.
send a asscii
hello
here i have a tcp socket...
I send from the NETIO App over the local Network a word "led on"
which order must i have for switch a digitalout 0 to 1?
my idea is a simple Code
if(incoming_data=="led on") {
led3=1;
but it doesnt work :-(
can anybody help me?
here my code:
  1. include "mbed.h"
  1. include "EthernetNetIf.h"
  1. include "TCPSocket.h"
DigitalOut led3(LED3);
DigitalOut led4(LED4, "led4");
DigitalOut led(LED1);
EthernetNetIf eth;
EthernetNetIf eth(
IpAddr(192,168,0,25), IP Address
IpAddr(255,255,255,0), Network Mask
IpAddr(192,168,0,1), Gateway
IpAddr(192,168,0,1) DNS
  1. define TCP_LISTENING_PORT 12345
TCPSocket ListeningSock;
TCPSocket* pConnectedSock; for ConnectedSock
Host client;
TCPSocketErr err;
void onConnectedTCPSocketEvent(TCPSocketEvent e)
{ switch(e)
{ case TCPSOCKET_CONNECTED:
printf("TCP Socket Connected\r\n");
break;
case TCPSOCKET_WRITEABLE:
printf("TCP Socket Writable\r\n");
break;
case TCPSOCKET_READABLE:
Can now read dome data...
printf("TCP Socket Readable\r\n");
Read in any available data into the buffer
char buff[128];
while ( int len = pConnectedSock->recv(buff, 128) ) {
And send straight back out again
pConnectedSock->send(buff, len);
buff[len]=0; make terminater
printf("Received&Wrote:%s\r\n",buff); } break;
case TCPSOCKET_CONTIMEOUT:
printf("TCP Socket Timeout\r\n");
break;
case TCPSOCKET_CONRST:
printf("TCP Socket CONRST\r\n");
break; case TCPSOCKET_CONABRT:
printf("TCP Socket CONABRT\r\n");
break;
case TCPSOCKET_ERROR:
printf("TCP Socket Error\r\n"); break;
case TCPSOCKET_DISCONNECTED:
Close socket...
printf("TCP Socket Disconnected\r\n");
pConnectedSock->close();
break;
default:
printf("DEFAULT\r\n");
void onListeningTCPSocketEvent(TCPSocketEvent e)
{ switch(e)
case TCPSOCKET_ACCEPT:
printf("Listening: TCP Socket Accepted\r\n");
Accepts connection from client and gets connected socket.
err=ListeningSock.accept(&client, &pConnectedSock);
if (err) {
printf("onListeningTcpSocketEvent : Could not accept connection.\r\n");
return; Error in accept, discard connection
} Setup the new socket events
pConnectedSock->setOnEvent(&onConnectedTCPSocketEvent);
We can find out from where the connection is coming by looking at the
Host parameter of the accept() method
IpAddr clientIp = client.getIp();
printf("Listening: Incoming TCP connection from %d.%d.%d.%d\r\n",
clientIp[0], clientIp[1], clientIp[2], clientIp[3]);
break;
the following cases will not happen
printf("Listening: TCP Socket Connected\r\n");
break;
printf("Listening: TCP Socket Writable\r\n");
break;
printf("Listening: TCP Socket Readable\r\n");
break;
printf("Listening: TCP Socket Timeout\r\n");
break;
printf("Listening: TCP Socket CONRST\r\n");
break;
printf("Listening: TCP Socket CONABRT\r\n");
break;
printf("Listening: TCP Socket Error\r\n");
break;
Close socket...
printf("Listening: TCP Socket Disconnected\r\n");
ListeningSock.close();
break;
default:
printf("\r\n");
printf("Setting up...\r\n");
EthernetErr ethErr = eth.setup();
if(ethErr)
{ printf("Error %d in setup.\r\n", ethErr);
return -1;
} printf("Setup OK\r\n");
IpAddr ip = eth.getIp();
printf("mbed IP Address is %d.%d.%d.%d\r\n", ip[0], ip[1], ip[2], ip[3]);
Set the callbacks for Listening
ListeningSock.setOnEvent(&onListeningTCPSocketEvent);
bind and listen on TCP
err=ListeningSock.bind(Host(IpAddr(), TCP_LISTENING_PORT));
printf("Binding..\r\n");
if(err)
{ Deal with that error...
printf("Binding Error\n");
} err=ListeningSock.listen(); Starts listening
printf("Listening...\r\n");
if(err)
{ printf("Listening Error\r\n");
Timer tmr;
tmr.start();
while(true)
{ Net::poll();
if(tmr.read() > 0.2) sec
{ led4=!led4; Show that we are alive
tmr.reset();
http://mbed.org/users/wango/code/TCP_server_FET10/
Thanks at least for sharing the code, because code above without the code highlighting is a bullet to a head. Anyway, what does not work there ? Be more specific, what does it print, where does it stop?
Do we really need to read line by line??
posted by Martin Kojtal 30 Oct 2013
