12 years, 5 months ago.
modbus: modpoll
Hi all,
I'm not sure if this is the right place to ask this question.
I wonder if anyone has ever used the "modpoll" tool before as a Modbus master polling tool? http://www.modbusdriver.com/modpoll.html
I'm testing it on my Modbus slave device whose address is based on PDU addressing. (Starting address is 0)
In the modpoll setup, we can use "-0" to set the first reference as 0 instead of 1.
However, the start reference parameter ("-r") is defined between 1-65536.
In this case, I couldn't get the value at register 0.
I tried to set the "-r" parameter 0 but it's invalid.
I tried to contact the modpoll website service but haven't got any reply from them.
Hope someone here could help. Thanks!
FYI:
Usage: modpoll [options] serialport|host
Arguments:
serialport Serial port when using Modbus ASCII or Modbus RTU protocol
COM1, COM2 ... on Windows
/dev/ttyS0, /dev/ttyS1 ... on Linux
/dev/ser1, /dev/ser2 ... on QNX
host Host name or dotted ip address when using MODBUS/TCP protocol
General options:
-m ascii Modbus ASCII protocol
-m rtu Modbus RTU protocol (default)
-m tcp MODBUS/TCP protocol
-m enc Encapsulated Modbus RTU over TCP
-a # Slave address (1-255, 1 is default)
-r # Start reference (1-65536, 100 is default)
-c # Number of values to poll (1-100, 1 is default)
-t 0 Discrete output (coil) data type
-t 1 Discrete input data type
-t 3 16-bit input register data type
-t 3:hex 16-bit input register data type with hex display
-t 3:int 32-bit integer data type in input register table
-t 3:mod 32-bit module 10000 data type in input register table
-t 3:float 32-bit float data type in input register table
-t 4 16-bit output (holding) register data type (default)
-t 4:hex 16-bit output (holding) register data type with hex display
-t 4:int 32-bit integer data type in output (holding) register table
-t 4:mod 32-bit module 10000 type in output (holding) register table
-t 4:float 32-bit float data type in output (holding) register table
-i Slave operates on big-endian 32-bit integers
-f Slave operates on big-endian 32-bit floats
-1 Poll only once, otherwise poll every second
-e Use Daniel/Enron single register 32-bit mode
-0 First reference is 0 (PDU addressing) instead 1
Options for MODBUS/TCP:
-p # TCP port number (502 is default)
Options for Modbus ASCII and Modbus RTU:
-b # Baudrate (e.g. 9600, 19200, ...) (9600 is default)
-d # Databits (7 or 8 for ASCII protocol, 8 for RTU)
-s # Stopbits (1 or 2, 1 is default)
-p none No parity
-p even Even parity (default)
-p odd Odd parity
-4 # RS-485 mode, RTS on while transmitting and another # ms after
-o # Time-out in seconds (0.01 - 10.0, 1.0 s is default)
