12 years, 5 months ago.
How to change the mbed-src to new customer board
I have a new customer board. And I want to try to use mbed compiler and most of their API/function (I hope) to program it. But the ciruit board connection is a lot different (pin etc), so could I ask which kind of file in mbed-src should I change to adjust new board?
Yiqing
You can always program using the 'real' pinnames. For example on the LPC1768 you can address port 0, pin 5, as P0_5. You can also always include your own header file where you define extra pinnames, for example:
#define Pin10 P0_5
And finally to really answer your question, pinnames are defined in: /targets/hal/[manufacturer]/[model]/PinNames.h
Device.h should be in the same folder. One of them has it in a sub-folder, but all others it should be in the same folder as PinNames.h.
posted by 17 Oct 2013
