12 years, 7 months ago.
Mbed Tickerfunction hangs system from revison 65
something has changed with revision 65 Mbed lib's and the ticker function. Now the systems hangs when i call a ticker.... revision 64 works fine. Any suggestion?
Could you please provide full reproducibility instructions for this issue? I wasn't able to reproduce it locally.
Thanks, Bogdan
posted by Bogdan Marinescu 28 Aug 2013
/media/uploads/bert1952/rtos-test.zip
try this example with rev 64 and 66 I'm using the ticker inside a thread. Is that a problem, and if so, why does it work on rev 64?
bert
posted by Gyro Gearloose 30 Aug 2013
12 years, 6 months ago.
Thanks, I can reproduce it now. Unfortunately, the fix isn't simple. It has to do with the new CallChain class and the fact that is uses new/delete (and in your particular case, detach calls CallChain::clear, which in turn does a delete in an interrupt context, hence the problem). I have to think about a proper fix for this.
Have a try, For the moment i'm happy with rev 64. It's needed to start/stop a pulsetrain generator. tnx bert
hi version 67 has still the same problem. I modified the code a bit, the the issue is the indeed the detachfunction.
posted by Gyro Gearloose 21 Sep 2013
Yes, still looking for a suitable solution. I might reverse the implementation of add/remove to the previous behaviour that didn't use call chains, which would fix the issue, but will remove a feature. But the alternatives don't look better, so this is what I'll probably do in the end.
posted by Bogdan Marinescu 23 Sep 2013
https://github.com/mbedmicro/mbed/commits/master/libraries/mbed/common/Ticker.cpp That code was changed around 2weeks ago.
Could you tell me more detail (e.g. platform) about this?
lpc1768 RTOS..... platform Mbed online compiler
any tickerattach (secs or usecs) will hang the system. like this flipper.attach_us(&flip, 300);
rev 64 is ok, rev 65,66 will have this problem
thanks
I reported this problem to mbed team. They will solve or reply to your question. :-)
posted by Yoshihiro TSUBOI 25 Aug 2013
