13 years, 2 months ago.
up and down errow keys detection with mbed ?
how can i detect the up an down arrow keys with mbed serially connected with a pc?
Took me a while to figure this out - so I'll save you the trouble!
This code snippet should get you started...
Serial term (USBTX,USBRX);
char Key;
        Key=term.getc();                              //Get the keypad pressed
        if(Key==0x1B) {                               //If the keypress was an arrow key
            Key = term.getc();                        //Check again!
            if (Key == 0x5B) {
                Key = term.getc();
                switch(Key) {                         //Check to see which arrow key...
                    case 0x41:                        //It was the UP arrow key...
                        term.printf("\n\r UP!");
                        break;
                    case 0x42:                        //It was the DOWN arrow key...
                        term.printf("\n\r DOWN!");
                        break;
                    case 0x43:                        //It was the RIGHT arrow key...
                        term.printf("\n\r RIGHT!");
                        break;
                    case 0x44:                        //It was the LEFT arrow key...
                        term.printf("\n\r LEFT!");
                        break;
You have to check 3 times to find out which arrow key was pressed. The 1st two times tells you that it was an arrow key and the 3rd time says which one. Strange???
Looks like a VT100 or ANSI escape code. Its a property of the terminal software though not the computer.
I'm guessing the serial terminal is in VT100 mode, and most special keys send an escape character (0x1B) followed by a sequence indicating what the key was.
The second character is "[" , I think there can be an optional digit indicating number of times to move, and the last is an uppercase letter. The information on the web is confusing.
posted by Oliver Broad 11 Oct 2013
works perfectly on KL25Z. I had already wasted a lot of time but it could have been much worse, THANK YOU!
posted by Ed Atchison 01 Jan 2017
