12 years, 7 months ago.
How to receive an IR code?
Hi
Can you help me how can i receive an IR code and then transmit it using the Same approach as you did actually i have to control an Acson Air Conditioner (On/Off) but i do not have the IR codes that are generated when the ON/OFF key is pressed on the remote so first i have to read the code and then transmit it.
Can you help me with this ?
Thanks
