12 years, 8 months ago.  This question has been closed. Reason: wrong topic
Poor power supply with OpenSDA-USB port on FRDM-KL25Z
I'm having some problems with the power supply on my FRDM-KL25Z. When hooked up to the PC via the OPenSDA USB port there seems to be some problem with the onboard voltage regulators / the power supply circuit. I first noticed the issue when trying to use the onboard RGB-led: the red one is quite bright but the blue and green ones are really dim. When powered by the KL25Z-USB port all leds are as bright as expected.
I measured the voltages on the different pins on the connector
powered by the OpenSDA port:
  • VIN: 3.6V
  • 5V-USB: 4.0V
  • 3.3V: 2.3V
powered by the KL25Z port:
  • VIN: 4.5V
  • 5V-USB: 4.8V
  • 3.3V: 2.9V
I'm on a mac mini 2010 model and also tried a powered USB-Hub, the voltages where a little higher, but not as high as you would expect.
Next thing I tried : another USB-cable, results:
more Volts at the pins with both USB connectors and brighter LEDs. AND:
magic smoke from diode D2 :(
Diode D2 is in the power supply circuit right before the 3.3V voltage regulator protecting it from reverse volatge (I guess).
Next thing I tried was powering the board from an external 8V power supply (+8V on VIN and GND to GND, nothing else connected to the board) witch resulted in diode D1 going up in smoke as well :(
Does anybody has an idea whats going wrong on my board?
Cheers
Max
