12 years, 8 months ago.
Samsung Chromebook
Will I be able to use the mbed compiler on my Chromebook and connect to the FRDM-KL25Z Freescale Freedom board.
No personal experience, however: the compiler shouldn't be a problem, it even runs on tablets. For programming I also don't expect issues. Unlocking the mbed bootloader might require a windows PC, but besides that it should just work on a chromebook: If it can use USB drivers it should also be able to program the KL25Z.
I also expect the serial port to work, but of that I am a bit less certain.
Thanks Erik, I'm able to run the compiler and I can unlock the bootloader at work so I'll give it a try.
posted by Steve Hoke 21 Jul 2013
12 years, 6 months ago.
@Steve Hoke : Did you succeed on making this work on a Chromebook ? The real question is actually: if you plug the KL25Z on the Chromebook to you get the MBED mass storage up and running ? Thanks
Yes it work just fine. Just as Erik stated you will need to use a windows computer first to unlock the bootloader then you are good to go.
posted by Steve Hoke 09 Oct 2013
Great ! then I'm really interrested in the new HP Chromebook with the ARM SoC :) Thanks for your quick answer. Anthony
posted by anthony harivel 09 Oct 2013
