12 years, 8 months ago.
micro sd card problem
i have lpc11u24 board.
i have microsd card break out board.
i used 8 gb kingston microsdhc card it is not getting detected.
following is error on my console..
i used this example SDFileSystem_HelloWorld.
Hello World! No disk, or could not put SD card in to SPI idle state Didn't get a response from the disk Set 512-byte block timed out No disk, or could not put SD card in to SPI idle state Didn't get a response from the disk Set 512-byte block timed out Could not open file for write
10 years, 3 months ago.
Having the same problem.LPC11U25 mcu (xadow m0 board) and SanDisk microSDHC 8GB card, cant get any respond.Have double checked my wiring.
11 years, 8 months ago.
Have you found out anything about this issue? Ive been seeing the same with my 1gb SanDisk SD card.
