12 years, 9 months ago.
error message
I have an error in my program. The description of the error is " not a class or structure name". what does that mean? I'll be honest with you. I have a little background about c++ programming. May be one of you can help me! . thanks
It helps when you publish the code. The error message means just what it says, the compiler found a construct in which it expects a class name but the identifier is not the name of a class. An example could be
class a { int i;} *obj; obj.i = 1;// here the compiler expects obj to be a classname, it is however a pointer name
