12 years, 8 months ago.
sample of code for adc at 10KHz, 5volts and display result via tera term
Hello Guys
please don't find me to be nasty. I just dont have any basics in c coding, and Mbed is new to me . have been trying for two weeks to see whether i could get any help. I kindly wish to seek any advise and assistance on the above issue.
I need a code for ADC at 10KHz, 5volts input and display result via tera term. and another adc at 100Hz, 1.20volts. both to be controlled by a switch, for switching between the two. please kindly come to my aid.
thanks
What exactly is the problem? For reading the ADC data you use the AnalogIn objects, for the samplerates you use Ticker objects, the range you have to solve in hardware. I don't know which switch you mean. To communicate with TeraTerm you use a Serial object. Please define your problem more precisely and provide us with the code you think is right so we can point you in the right direction. The objects you require are described in the handbook. Regarding C/C++ coding there is information on the internet and in many, many books.
posted by Ad van der Weiden 08 Jul 2013
thanks for spearing your time to read my request. Am to use the internal ADC of Mbed NXP LPC1768 and display its output on a pc via tera term. the system has two cut off frequencies which is controlled by a switch i.e. for switching between the cut off frequencies of 10KHz and 100Hz. the voltage from the signal generator to the mbed is 4.5volts, which will go through high pass filter and, then switched to 1.20volts to go through a low pass filter. this will be implemented in hardware, then use the ADC of the Mbed and display the result via pc using tera term. the problem am having is the c code for adc conversion (Mbed) for the above frequencies. expecting your reply.. thanks
posted by Alhassan umar 09 Jul 2013
