12 years, 8 months ago.
Light a LED using a 3-ping toggle switch
basic question, im trying to place a 3-pin Toggle Switch with On-Off-On in between my LED and Mbed.
this is how i think it would work, tho i havent tested it yet. just wanted to verify if this setup is correct.
If it is correct depends on your goal. If the LED should only light when both the switch and the mbed code tells it should be on, then yes it should work.
posted by Erik - 07 Jul 2013
