12 years, 8 months ago.
c code for ADC conversion using mbed which will log the output via the mbed serial to a pc
Hello Guys
please am new to C programming and Mbed. Am asked to write a c-code for ADC conversion using Mbed, then log the output via the serial port to a PC. am to that using tera term also. The issue is that, the ADC works in two ways, when I turn a switch on (high), the high-pass filter (10KHz) is activated. But when the switch is off, the low-pass-filter (100Hz) is activated. both are connected to the adc. Also, am to log the output of the Mbed's adc to a pc via the serial port on Mbed and tera term. right now, am able to compile hello world on the mbed, then display it on tera -term window.
what i need now is the c-code to implement the above and any other advise is very welcome. Thanks in advance
11 years, 11 months ago.
hey the same thing is ben asked by my senior pls do helpout with what should be done....
Look into the temperature sensor code mbed.org website of the application board provided with the embed. That will help
