12 years, 9 months ago.
Download to MCB1760 with Keil uVision Problem
After exporting an mbed project to Keil uVision4 for 1768 target hardware I have a problem. I can build the project, but download with ULINK2 fails. I get the follow error message from Keil uVision4. Does anyone know what the problem is and how to get around it? Thanks
Cannot load driver 'C:\Keil\ARM\BIN\CMSIS_AGDI.dll'.
Possible Reasons: - Driver DLL could not be found in the specified path - Driver DLL requires additional DLL's which are not installed - Required Hardware Drivers are not installed
Did you select the correct programmer interface. There is a setting somewhere to select ulink, jlink, cmsis dap etc.
Maybe you need to install the driver first.
There are some other problem reports here: http://www.keil.com/forum/23136/
