12 years, 10 months ago.
DigitalIn initial value
Hi team,
When pin 8 is open, the following program displays 1 then 0 when compiled with the latest (rev.63) mbed library. But the output should be 0 then 0 according to the DigitalIn handbook.
DigitalIn digitalIn(p8);
    printf("%d\n", digitalIn.read());
Any suggestions?
Hiroshi
Random idea, but default state of all pins is pull-up enabled. As soon as you make a DigitalIn object it will enable the pull-down, but it takes a very short amount of time to discharge the input capacitance when the pull-down is activated. If you immediatly read the input it might still be high.
Erik,
Thanks for the exlanation. If I put a very small delay, less than 1 us, the program displays as I expected.
BTW, this behavior seems to have been introduced since the r44 build, when the refactoringof the core library was made.
Hiroshi
