12 years, 10 months ago.
Are digital pins rtos safe?
So I'm working on writing a RTOS application that has GPS, Bluetooth, LEDs, etc. All of these things are on different pins, but am I going to have a problem with one thread turning one LED on(say PTE1) and another doing something with another pin on the same port(say PTE2)?
No, actions on one pin should not affect any other pin, regardless of the port they are on.
Maybe there is a communication error, but I mean do I need a mutex in my rtos for each port?
posted by 17 May 2013Ah like that.
I haven't used RTOS myself, but if I understand it correctly you should not need a mutex for each port. Each pin of a port is controlled completely independent of other pins. Only if you would use a pin for several purposes you would need a mutex for it (that won't happen often, but there are some use cases for it).
But the tl;dr is that writing/read/setting mode of one pin should have no influence/dependence on other pins, so from what I understand then a mutex is not required.
