12 years, 10 months ago.
Net::poll();
This comes from an HelloWorld Server example with the old Ethernet Interface
What does this actually do? Is this like:
poll() is used to check on the state of a socket in a set of sockets. The set can be tested to see if any socket can be written to, read from or if an error occurred.
Or does this means:
check WHAT and not IF there is something comming in in the socket.
thnx!
With the old LwIP libraries, which cannot run under RTOS, data is not moved anywhere until the net::poll() function is called.
For example, say you have set up a connexion to a remote device (you issued a LwIP tcp_connect() ). This will send the introductory SYN to the remote end, but when you receive some data back, this will not be available until you have called a net::poll().
when the net::poll() is called, the LwIP layer will check the receive buffer for data, and start your receive callback if there is something waiting.
Yes, it's a bit manual-operated - but it actually works very reliably. Used with the LwIP raw TCP or UDP API, it is much more robust than any of the available high-level libraries, IME.
http://lwip.wikia.com/wiki/Raw/TCP
