I trying to add support for the Cortex M4 on the MIMX8MQ6. Here are the steps I have taken:
1) Port over the MCUXpresso SDK for the chip
- Copy the drivers folder into targets/TARGET_NXP/TARGET_MCUXpresso_MCUS/TARGET_MIMX8MQ6
- Copy the fsl_device_registers.h, MIMX8MQ6_cm4.h, MIMX8MQ6_cm4_features.h, system_MIMX8MQ6_cm4.h, system_MIMX8MQ6_cm4.h into the TARGET_MIMX8MQ6/device
- Added the cmsis.h and cmsis_nvic.h with #define NVIC_NUM_VECTORS (16 + 128) CORE + MCU Peripherals
- Port over the linker and startup files for TOOLCHAIN_GCC_ARM
2) Add new targets to the targets.json:
"MIMX8MQ6": {
"core": "Cortex-M4F",
"supported_toolchains": ["GCC_ARM"],
"extra_labels": ["NXP", "MCUXpresso_MCUS", "MIMX8MQ6"],
"is_disk_virtual": true,
"macros": ["CPU_MIMX8MQ6DVAJZ"],
"inherits": ["Target"],
"device_has": [
"SERIAL",
"MPU"
"device_name": "MIMX8MQ6"
"DARTMX8M": {
"inherits": ["MIMX8MQ6"],
"extra_labels": ["NXP", "MCUXpresso_MCUS", "MIMX8MQ6", "DARTMX8M"]
3) Updated the TARGET_NXP/mbed_rtx.h file to support the new chip
#elif defined(TARGET_MIMX8MQ6)
#ifndef INITIAL_SP
#define INITIAL_SP (0x20020000UL)
#endif
4) Implemented both Serial and GPIO API for testing.
When I try to run the compile the mbed-os-example-blinky targeting that board: mbed compile target DARTMX8M toolchain GCC_ARM , it seems to compile successfully but I get a linking error: ld.exe: region m_text overflowed with text and data
How can I resolve this? Are there any steps I am missing?
Below is the linker file I modified from the MCUXpresso SDK to work with mbed:
/* Entry Point */
ENTRY(Reset_Handler)
__ram_vector_table__ = 1;
#if !defined(MBED_BOOT_STACK_SIZE)
#define MBED_BOOT_STACK_SIZE 0x400
#endif
__stack_size__ = MBED_BOOT_STACK_SIZE;
STACK_SIZE = DEFINED(__stack_size__) ? __stack_size__ : 0x0400;
M_VECTOR_RAM_SIZE = DEFINED(__ram_vector_table__) ? 0x0240 : 0x0;
/* Specify the memory areas */
MEMORY
m_interrupts (RX) : ORIGIN = 0x1FFE0000, LENGTH = 0x00000240
m_text (RX) : ORIGIN = 0x1FFE0240, LENGTH = 0x0001FDC0
m_data (RW) : ORIGIN = 0x20000000, LENGTH = 0x00020000
m_data2 (RW) : ORIGIN = 0x80000000, LENGTH = 0x01000000
/* Define output sections */
SECTIONS
/* The startup code goes first into internal RAM */
.interrupts :
__VECTOR_TABLE = .;
. = ALIGN(8);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(8);
} > m_interrupts
/* The program code and other data goes into internal RAM */
.text :
. = ALIGN(8);
*(.text) /* .text sections (code) */
*(.text*) /* .text* sections (code) */
*(.rodata) /* .rodata sections (constants, strings, etc.) */
*(.rodata*) /* .rodata* sections (constants, strings, etc.) */
*(.glue_7) /* glue arm to thumb code */
*(.glue_7t) /* glue thumb to arm code */
*(.eh_frame)
KEEP (*(.init))
KEEP (*(.fini))
. = ALIGN(8);
} > m_text
.ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > m_text
.ARM :
__exidx_start = .;
*(.ARM.exidx*)
__exidx_end = .;
} > m_text
.ctors :
__CTOR_LIST__ = .;
/* gcc uses crtbegin.o to find the start of
the constructors, so we make sure it is
first. Because this is a wildcard, it
doesn't matter if the user does not
actually link against crtbegin.o; the
linker won't look for a file to match a
wildcard. The wildcard also means that it
doesn't matter which directory crtbegin.o
is in. */
KEEP (*crtbegin.o(.ctors))
KEEP (*crtbegin?.o(.ctors))
/* We don't want to include the .ctor section from
from the crtend.o file until after the sorted ctors.
The .ctor section from the crtend file contains the
end of ctors marker and it must be last */
KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors))
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
__CTOR_END__ = .;
} > m_text
.dtors :
__DTOR_LIST__ = .;
KEEP (*crtbegin.o(.dtors))
KEEP (*crtbegin?.o(.dtors))
KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors))
KEEP (*(SORT(.dtors.*)))
KEEP (*(.dtors))
__DTOR_END__ = .;
} > m_text
.preinit_array :
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP (*(.preinit_array*))
PROVIDE_HIDDEN (__preinit_array_end = .);
} > m_text
.init_array :
PROVIDE_HIDDEN (__init_array_start = .);
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array*))
PROVIDE_HIDDEN (__init_array_end = .);
} > m_text
.fini_array :
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP (*(SORT(.fini_array.*)))
KEEP (*(.fini_array*))
PROVIDE_HIDDEN (__fini_array_end = .);
} > m_text
.interrupts_ram :
. = ALIGN(8);
__VECTOR_RAM__ = .;
__interrupts_ram_start__ = .; /* Create a global symbol at data start */
*(.m_interrupts_ram) /* This is a user defined section */
. += M_VECTOR_RAM_SIZE;
. = ALIGN(8);
__interrupts_ram_end__ = .; /* Define a global symbol at data end */
} > m_data
__VECTOR_RAM = DEFINED(__ram_vector_table__) ? __VECTOR_RAM__ : ORIGIN(m_interrupts);
__RAM_VECTOR_TABLE_SIZE_BYTES = DEFINED(__ram_vector_table__) ? (__interrupts_ram_end__ - __interrupts_ram_start__) : 0x0;
__etext = .; /* define a global symbol at end of code */
__DATA_ROM = .; /* Symbol is used by startup for data initialization */
.data : AT(__DATA_ROM)
. = ALIGN(8);
__DATA_RAM = .;
__data_start__ = .; /* create a global symbol at data start */
*(.data) /* .data sections */
*(.data*) /* .data* sections */
KEEP(*(.jcr*))
. = ALIGN(8);
__data_end__ = .; /* define a global symbol at data end */
} > m_data
__CACHE_REGION_START = ORIGIN(m_interrupts);
__CACHE_REGION_SIZE = 0;
__NDATA_ROM = __DATA_ROM + SIZEOF(.data); /* Symbol is used by startup for ncache data initialization */
.ncache.init : AT(__NDATA_ROM)
__noncachedata_start__ = .; /* create a global symbol at ncache data start */
*(NonCacheable.init)
. = ALIGN(8);
__noncachedata_init_end__ = .; /* create a global symbol at initialized ncache data end */
} > m_data2
. = __noncachedata_init_end__;
.ncache :
*(NonCacheable)
. = ALIGN(8);
__noncachedata_end__ = .; /* define a global symbol at ncache data end */
} > m_data2
__DATA_END = __DATA_ROM + (__data_end__ - __data_start__);
text_end = ORIGIN(m_text) + LENGTH(m_text);
ASSERT(__DATA_END <= text_end, "region m_text overflowed with text and data")
/* Uninitialized data section */
.bss :
/* This is used by the startup in order to initialize the .bss section */
. = ALIGN(8);
__START_BSS = .;
__bss_start__ = .;
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(8);
__bss_end__ = .;
__END_BSS = .;
} > m_data
.heap :
. = ALIGN(8);
__end__ = .;
PROVIDE(end = .);
__HeapBase = .;
. = ORIGIN(m_data) + LENGTH(m_data) - STACK_SIZE;
__HeapLimit = .;
__heap_limit = .; /* Add for _sbrk */
} > m_data
.stack :
. = ALIGN(8);
. += STACK_SIZE;
} > m_data
/* Initializes stack on the end of block */
__StackTop = ORIGIN(m_data) + LENGTH(m_data);
__StackLimit = __StackTop - STACK_SIZE;
PROVIDE(__stack = __StackTop);
.ARM.attributes 0 : { *(.ARM.attributes) }
ASSERT(__StackLimit >= __HeapLimit, "region m_data overflowed with stack and heap")
"MIMX8MQ6": { "core": "Cortex-M4F", "supported_toolchains": ["GCC_ARM"], "extra_labels": ["NXP", "MCUXpresso_MCUS", "MIMX8MQ6"], "is_disk_virtual": true, "macros": ["CPU_MIMX8MQ6DVAJZ"], "inherits": ["Target"], "device_has": [ "SERIAL", "MPU" ], "device_name": "MIMX8MQ6" }, "DARTMX8M": { "inherits": ["MIMX8MQ6"], "extra_labels": ["NXP", "MCUXpresso_MCUS", "MIMX8MQ6", "DARTMX8M"] },3) Updated the TARGET_NXP/mbed_rtx.h file to support the new chip
target DARTMX8Mtoolchain GCC_ARM , it seems to compile successfully but I get a linking error: ld.exe: region m_text overflowed with text and dataHow can I resolve this? Are there any steps I am missing?
/* Entry Point */ ENTRY(Reset_Handler) __ram_vector_table__ = 1; #if !defined(MBED_BOOT_STACK_SIZE) #define MBED_BOOT_STACK_SIZE 0x400 #endif __stack_size__ = MBED_BOOT_STACK_SIZE; STACK_SIZE = DEFINED(__stack_size__) ? __stack_size__ : 0x0400; M_VECTOR_RAM_SIZE = DEFINED(__ram_vector_table__) ? 0x0240 : 0x0; /* Specify the memory areas */ MEMORY { m_interrupts (RX) : ORIGIN = 0x1FFE0000, LENGTH = 0x00000240 m_text (RX) : ORIGIN = 0x1FFE0240, LENGTH = 0x0001FDC0 m_data (RW) : ORIGIN = 0x20000000, LENGTH = 0x00020000 m_data2 (RW) : ORIGIN = 0x80000000, LENGTH = 0x01000000 } /* Define output sections */ SECTIONS { /* The startup code goes first into internal RAM */ .interrupts : { __VECTOR_TABLE = .; . = ALIGN(8); KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(8); } > m_interrupts /* The program code and other data goes into internal RAM */ .text : { . = ALIGN(8); *(.text) /* .text sections (code) */ *(.text*) /* .text* sections (code) */ *(.rodata) /* .rodata sections (constants, strings, etc.) */ *(.rodata*) /* .rodata* sections (constants, strings, etc.) */ *(.glue_7) /* glue arm to thumb code */ *(.glue_7t) /* glue thumb to arm code */ *(.eh_frame) KEEP (*(.init)) KEEP (*(.fini)) . = ALIGN(8); } > m_text .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } > m_text .ARM : { __exidx_start = .; *(.ARM.exidx*) __exidx_end = .; } > m_text .ctors : { __CTOR_LIST__ = .; /* gcc uses crtbegin.o to find the start of the constructors, so we make sure it is first. Because this is a wildcard, it doesn't matter if the user does not actually link against crtbegin.o; the linker won't look for a file to match a wildcard. The wildcard also means that it doesn't matter which directory crtbegin.o is in. */ KEEP (*crtbegin.o(.ctors)) KEEP (*crtbegin?.o(.ctors)) /* We don't want to include the .ctor section from from the crtend.o file until after the sorted ctors. The .ctor section from the crtend file contains the end of ctors marker and it must be last */ KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)) KEEP (*(SORT(.ctors.*))) KEEP (*(.ctors)) __CTOR_END__ = .; } > m_text .dtors : { __DTOR_LIST__ = .; KEEP (*crtbegin.o(.dtors)) KEEP (*crtbegin?.o(.dtors)) KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)) KEEP (*(SORT(.dtors.*))) KEEP (*(.dtors)) __DTOR_END__ = .; } > m_text .preinit_array : { PROVIDE_HIDDEN (__preinit_array_start = .); KEEP (*(.preinit_array*)) PROVIDE_HIDDEN (__preinit_array_end = .); } > m_text .init_array : { PROVIDE_HIDDEN (__init_array_start = .); KEEP (*(SORT(.init_array.*))) KEEP (*(.init_array*)) PROVIDE_HIDDEN (__init_array_end = .); } > m_text .fini_array : { PROVIDE_HIDDEN (__fini_array_start = .); KEEP (*(SORT(.fini_array.*))) KEEP (*(.fini_array*)) PROVIDE_HIDDEN (__fini_array_end = .); } > m_text .interrupts_ram : { . = ALIGN(8); __VECTOR_RAM__ = .; __interrupts_ram_start__ = .; /* Create a global symbol at data start */ *(.m_interrupts_ram) /* This is a user defined section */ . += M_VECTOR_RAM_SIZE; . = ALIGN(8); __interrupts_ram_end__ = .; /* Define a global symbol at data end */ } > m_data __VECTOR_RAM = DEFINED(__ram_vector_table__) ? __VECTOR_RAM__ : ORIGIN(m_interrupts); __RAM_VECTOR_TABLE_SIZE_BYTES = DEFINED(__ram_vector_table__) ? (__interrupts_ram_end__ - __interrupts_ram_start__) : 0x0; __etext = .; /* define a global symbol at end of code */ __DATA_ROM = .; /* Symbol is used by startup for data initialization */ .data : AT(__DATA_ROM) { . = ALIGN(8); __DATA_RAM = .; __data_start__ = .; /* create a global symbol at data start */ *(.data) /* .data sections */ *(.data*) /* .data* sections */ KEEP(*(.jcr*)) . = ALIGN(8); __data_end__ = .; /* define a global symbol at data end */ } > m_data __CACHE_REGION_START = ORIGIN(m_interrupts); __CACHE_REGION_SIZE = 0; __NDATA_ROM = __DATA_ROM + SIZEOF(.data); /* Symbol is used by startup for ncache data initialization */ .ncache.init : AT(__NDATA_ROM) { __noncachedata_start__ = .; /* create a global symbol at ncache data start */ *(NonCacheable.init) . = ALIGN(8); __noncachedata_init_end__ = .; /* create a global symbol at initialized ncache data end */ } > m_data2 . = __noncachedata_init_end__; .ncache : { *(NonCacheable) . = ALIGN(8); __noncachedata_end__ = .; /* define a global symbol at ncache data end */ } > m_data2 __DATA_END = __DATA_ROM + (__data_end__ - __data_start__); text_end = ORIGIN(m_text) + LENGTH(m_text); ASSERT(__DATA_END <= text_end, "region m_text overflowed with text and data") /* Uninitialized data section */ .bss : { /* This is used by the startup in order to initialize the .bss section */ . = ALIGN(8); __START_BSS = .; __bss_start__ = .; *(.bss) *(.bss*) *(COMMON) . = ALIGN(8); __bss_end__ = .; __END_BSS = .; } > m_data .heap : { . = ALIGN(8); __end__ = .; PROVIDE(end = .); __HeapBase = .; . = ORIGIN(m_data) + LENGTH(m_data) - STACK_SIZE; __HeapLimit = .; __heap_limit = .; /* Add for _sbrk */ } > m_data .stack : { . = ALIGN(8); . += STACK_SIZE; } > m_data /* Initializes stack on the end of block */ __StackTop = ORIGIN(m_data) + LENGTH(m_data); __StackLimit = __StackTop - STACK_SIZE; PROVIDE(__stack = __StackTop); .ARM.attributes 0 : { *(.ARM.attributes) } ASSERT(__StackLimit >= __HeapLimit, "region m_data overflowed with stack and heap") }
