Deprecated This team is no longer maintained, please use: https://github.com/ARMmbed/mbed-mqtt instead.
Impliment MQTT on top of TCP/IP using SIM800
15 Dec 2017
Hello I want to publish some data(dummy) on server over MQTT protocol through SIM800 GSM/GPRS module. I am using TM4C123GXL-Launchpad.i send AT commands to GSM module using uart of TM4C123 controller and creat TCP socket using following AT command send using uart AT AT+CSTT='BSNLNET",","" AT+CIICR AT+CIFSR AT+CIPSTART="TCP","iot.eclipse.org","1883" AT+CIPSEND socket creat sucessfully. now i want to implement MQTT protocol on top of TCP/IP
please help how implement MQTT on top of TCP/IP
19 Dec 2017
Here is the MQTT Example : https://os.mbed.com/teams/mqtt/code/HelloMQTT/
If you are using a different connectivity module you will need to either find a library for it or write a library for it that impliments the networking spec so the MQTT library can then use it.
-Austin
