This would be good to have documented somewhere.
On FRDM-K22F, the same signals from the MCU used for D14 and D15 are also connected to the Open SDA (debug circuit) uart connection (UART1_TX, UART1_RX) for virtual com port.
So, if you are using a shield that requires I2C operation on D14, D15, then don't expect the usb virtual com port interface to continue to work and vice/versa. You can possibly jump back and forth between functions if you re-initialize the desired function each time.
