Just a quick note to people thinking of using this board with arduino modules: make sure you do not use arduino headers with components near the top right side of the board on the underside (towards the seeed arch max) or boards with through-hole components in this area.
Why? The Ethernet port is the same height as the header connectors, this means DIP components WILL short out (this happened to me) and components can also short out.
You can also get header risers that will give more clearance to boards.
