I found NUCLEO-F401RE has problem on OS-5 SPI API. When I created SPI by using the constructor with 4 parameters:
SPI spi(SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS);
the program could not run correctly. The LD2 LED is blinking (even the LD2 is not defined in the program) and the program hangs. The SPI constructor with 3 parameters has no problem.
