I have noticed a weird issue with the analog inputs on these boards (specifically A0 and A1), which seem to read much lower than they should via the ADC using a tmp36 temperature sensor.
I get realistic readings from the other pins (~ 18 degrees), but A0 and A1 give much lower readings ...
However, I can't replicate this with a potentiometer. Could it be something to do with the input impedance on those pins?
Regard,
Alex
