Hi! Using PC_1 for SPI3_MOSI leads to pinmap mis-match. But datasheet (p48) says this pin can handle SPI2_MOSI and SPI3_MOSI. With the HAL library and code generated from STM32CubeMX it works well, but mbed says no.
Could you fix this in code and documentation?
I can use an other pin at the moment, so this issue has no high priority.
