CAN-Bus Breakout Board
23 Aug 2010
This CAN-Bus Breakout board designed for use with mbed module. The CAN output are on both screw terminal and DB9 connector
Features
  • MCP2551 CAN Transceiver
  • 5v supply
  • Supports 1 Mb/s operation
  • Implements ISO-11898 standard physical layer requirements
  • Up to 112 nodes can be connected
  • DB9 and screw terminal connection
  • DB9 can be configure for OBDII cable or CAN Analyser pin-out
  • 120R terminating resistor via jumper
Product Link:
