NUCLEO-STM32F767ZI with RA8875 library
27 Apr 2019
Library RA8875 not work with this board, screen is black, but work with Adafruit_RA8875 on mbed.
include "mbed.h" testing: v147 - working: v146, v145, v142, v136, v128, fails: v148 include "RA8875.h" v138 - tested working include "MyFont18x32.h" include "BPG_Arial08x08.h" include "BPG_Arial10x10.h" include "BPG_Arial20x20.h" include "BPG_Arial31x32.h" include "BPG_Arial63x63.h"
define MOSI D11 define MISO D12 define SCLK D13 define CS D10 define RST D9
RA8875 lcd(MOSI, MISO, SCLK, CS, RST, "tft"); MOSI, MISO, SCK, /ChipSelect, /reset, name
LocalFileSystem local("local"); access to calibration file for resistive touch and printscreen
define LCD_C 16 color - bits per pixel define LCD_W 800 define LCD_H 480
Serial pc(USBTX, USBRX); And a little feedback Timer measurement;
RetCode_t callback(RA8875::filecmd_t cmd, uint8_t * buffer, uint16_t size) { static FILE * fh = NULL; static unsigned int bytesDone = 0; static unsigned int totalBytes = 0;
switch(cmd) { case RA8875::OPEN: bytesDone = 0; totalBytes = *(uint32_t *)buffer; pc.printf("PrintScreen callback to write %u bytes\r\n", totalBytes); fh = fopen("/local/file.bmp", "w+b"); if (!fh) return(file_not_found); break; case RA8875::WRITE: bytesDone += size; pc.printf(" Write %d bytes => %d of %d\r\n", size, bytesDone, totalBytes); fwrite(buffer, 1, size, fh); pc.printf(" %3d %% complete\r\n", ((100 * bytesDone)/totalBytes)); break; case RA8875::CLOSE: fclose(fh); pc.printf("PrintScreen Closed.\r\n"); break; default: pc.printf("Unexpected callback %d\r\n", cmd); break; } return noerror; }
int main() { pc.baud(9600); I like a snappy terminal, so crank it up! pc.printf("\r\nRA8875 Soft Fonts - Build " DATE " " TIME "\r\n");
measurement.start(); lcd.init(LCD_W, LCD_H, LCD_C); lcd.Backlight(0.5f);
lcd.cls();
****** RunTestSet(lcd, pc); If the library was compiled for test mode...
lcd.foreground(Blue); lcd.puts(0,100, "RA8875 Soft Fonts - Build " DATE " " TIME "\r\n");
lcd.SelectUserFont(Dave_Smart18x32); lcd.puts(" ! Soft Fonts ! 0123456789\r\n"); lcd.puts("ABCDEFGHIJKLMNOPQRSTUVWXYZ\r\n"); lcd.puts("abcdefghijklmnopqrstuvwxyz\r\n"); lcd.SelectUserFont(); lcd.puts("Back to normal\r\n"); lcd.SelectUserFont(BPG_Arial08x08); lcd.puts("BPG_Arial08x08 ABCDEFGHIJKLMNOPQRSTUVWXYZ\r\n"); lcd.puts("BPG_Arial08x08 abcdefghijklmnopqrstuvwxyz\r\n"); lcd.SelectUserFont(BPG_Arial10x10); lcd.puts("BPG_Arial10x10 ABCDEFGHIJKLMNOPQRSTUVWXYZ\r\n"); lcd.puts("BPG_Arial10x10 abcdefghijklmnopqrstuvwxyz\r\n"); lcd.SelectUserFont(BPG_Arial20x20); lcd.puts("BPG_Arial20x20 "); lcd.SelectUserFont(BPG_Arial31x32); lcd.puts("BPG_Arial31x32\r\n"); lcd.SelectUserFont(BPG_Arial63x63); lcd.puts("BPG_Arial63x63"); pc.printf("Time trial completed in %d uSec\r\n", measurement.read_us());
lcd.rect(0,0, 10,10, BrightRed);
/* pc.printf("PrintScreen activated ...\r\n"); RetCode_t r = lcd.PrintScreen(0,0,LCD_W,LCD_H,"/local/file.bmp", 8); pc.printf(" PrintScreen returned %d - %s\r\n", r, lcd.GetErrorMessage(r));*/
lcd.AttachPrintHandler(callback); lcd.PrintScreen(0,0,LCD_W,LCD_H,8);
end
i use tft 5" and RA8875 board from adafruit.
Thanks for your responses.
19 Nov 2019
switch (cmd) {case RA8875 :: OPEN: byteDone = 0; bộ đệm TotalBytes = * (uint32_t *); pc.printf ("Gọi lại PrintScreen để ghi% u byte \ r \ n", TotalBytes); fh = fopen ("/ local / file.bmp", "w + b"); if (! fh) return (file_not_found); phá vỡ; trường hợp RA8875 :: VIẾT: byteDone + = size; pc.printf ("Viết% d byte =>% d của% d \ r \ n", kích thước, byteDone, TotalBytes); fwrite (bộ đệm, 1, kích thước, fh); pc.printf ("% 3d %% hoàn thành \ r \ n", ((100 * byteDone) / TotalBytes)); phá vỡ; trường hợp RA8875 :: ĐÓNG: fc Đóng (fh); pc.printf ("PrintScreen đã đóng. \ r \ n"); phá vỡ; mặc định: pc.printf ("
